Event for ConnectionReleased
stefan.palm
stefan.palm
There should be an event for when user logout from vault. How do i attach to this "ConnectionReleased" event?
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @stefan.palm,
You can register to the ConnectionReleased event as below:
 Autodesk.DataManagement.Client.Framework.Vault.Library.ConnectionManager.ConnectionReleased += ConnectionManager_ConnectionReleased;
private void ConnectionManager_ConnectionReleased(object sender, VDF.Vault.Currency.Connections.ConnectionEventArgs e)
          // Required functionality
If you are using an IExplorerExtension, you can put your required code directly in the OnLogOff method.
Sajith
Sajith Subramanian
Autodesk Developer Network
