Error loading extension (versioning)
dk941
dk941
Hello
Help pls
"Error loading extension C:\ProgramData\Autodesk\Vault 2018\Extensions|Test\Test.vcet.confog"
The extension works fine on version Vault  2017.
When installing the extension to version Vault 2018, an error occurred.
how to solve the versioning problem?
cbenner
dk941
@cbenner
As far as I know, all of the necessary .dll files in that folder present.
The extension works without problems for version AutodeskVault Professional 2017.
What changes need to be made to the extension to work in version Autodesk Vault Professional 2018?
Markus.Koechl
Did you update the API version? Probably your extension registers the 2017 value of "10.0"
[assembly: ApiVersion("11.0")]
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
dk941
Yes! Thank you!
