Error calling VaultVirtualPath since Inventor 2018
In my addin I got code which makes a call to the get of property VaultVirtualPath() from object DesignProject.
My addin worked in Inventor 2014 but since executing it in Inventor 2018 I got the following exception message :
The API documentation says that the property is applicable only if "ProjectType is set to kVaultMode". I tried to set it in my default test project and it doesn't change anything.
Any idea of the meaning of this error ?
Best regards,
Gaël
junyi_zhu
This is actually an Inventor API so you may also want to try Inventor forum. From Vault perspective, can you try it with a vault project and with proper folder mappings? You can set up the mappings in Vault ribbon tab, "Assess" group, "Map folders" drop down.
Junyi Zhu
@junyi_zhu Actually my post was moved here by a moderator ( @kelly.young).
Yes, my code is an Inventor addin.
I guess I have a problem with project dependencies (with InteropServices) but I have updated dependencies versions and all seems ok (see attachment).
psaarloos
Hi Gaël,
I've tested it, but I don't get an exception. It actually looks like there is an old reference to the Inventor API in your project. Maybe you had an older version on Inventor installed before. The Inventor.Interop gets installed in the GAC. It seems your application load version 16.0, while it should load version 22. Try to delete the reference of Autodesk.Inventor.Interop from your project and add it again from the location below.
C:\Program Files\Autodesk\Inventor 2018\Bin\Public Assemblies\Autodesk.Inventor.Interop.dll
Hope it helps!
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
Hi Pim,
sorry for the late reply.
Yes that was it ! I upgraded the version of Interop dll as you told me and it solved the problem.
Thank you !
Best Regards
Gaël
