DataStandard - XAML not working in VisualStudio 2022
d_stockinger
d_stockinger
I just migrated a DataStandard "Project" from VisualStudio 2019 to VisualStudio 2022.
In 2019 everything was fine. The Preview of the XAML did work well.
After migrating to VisualStudio 2022, I just get no preview, instead of that, I get a Error Message.
The blue dot in the PreView:
Here is the Link to MoreInfo
https://go.microsoft.com/fwlink/?linkid=2026125
But switching this Options makes no difference, as mentioned in the Link.
All Referenced DLLs are available
Configuration Manager is set to x64
How can I fix this?
any help is appreciated
Daniel
Markus.Koechl
Thank you for the heads-up. I hope you understand that this is not a priority to look at as Vault SDK (including the latest 2023 release) refers to Visual Studio 2019.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
jose_oltra
Hello @d_stockinger
Got the same issue.  The message says "Building the application may let you view this control" and it's exactly what you need.
Press F5 to start the application, you will get a blank window. After closing the window you will return to the designer with all the controls visible
Inventor
Revit
Vault Professional
Autocad
