DataStandard: WPF Validated Binding is not working
In one of my xaml Configuration for Inventor i want to use the WPF function ValidatedBinding Prop from the coolorange blog:
https://blog.coolorange.com/2015/08/21/data-standard-dynamic-properties/
But every time i use this function, my dialog doesn't work any more Smiley Sad
I have installed the update 3 for DS 2016.
At the beginning of the xaml, the namespace for wpf
               xmlns:behaviours="clr-namespace:Common.Wpf;assembly=Common"
               xmlns:WPF="clr-namespace:CreateObject.WPF;assembly=CreateObject"
For my textbox
<TextBox Grid.Row="0" Grid.Column="1" Text="{WPF:ValidatedBinding Prop[Title].Value}"/>
Error from the DS log file
2016-04-07 15:22:08,503 [1] ERROR dataStandard.InvAddIn.EventHandlers.MyViewCallerBaseMulti - Exception when calling myView
System.Windows.Markup.XamlParseException: Zeilennummer "218" und Zeilenposition "63" von "Der unbekannte Typ "{clr-namespace:CreateObject.WPF;assembly=CreateObject}ValidatedBinding" kann nicht erstellt werden.". ---> System.Xaml.XamlObjectWriterException: Zeilennummer "218" und Zeilenposition "63" von "Der unbekannte Typ "{clr-namespace:CreateObject.WPF;assembly=CreateObject}ValidatedBinding" kann nicht erstellt werden.".
   bei System.Xaml.XamlObjectWriter.WriteStartObject(XamlType xamlType)
   bei System.Windows.Markup.WpfXamlLoader.WriteStartObject(XamlReader xamlReader, XamlObjectWriter xamlWriter, XamlContextStack`1 stack)
   bei System.Windows.Markup.WpfXamlLoader.TransformNodes(XamlReader xamlReader, XamlObjectWriter xamlWriter, Boolean onlyLoadOneNode, Boolean skipJournaledProperties, Boolean shouldPassLineNumberInfo, IXamlLineInfo xamlLineInfo, IXamlLineInfoConsumer xamlLineInfoConsumer, XamlContextStack`1 stack, IStyleConnector styleConnector)
   bei System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
   --- Ende der internen Ausnahmestapelüberwachung ---
   bei System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
   bei System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, Boolean skipJournaledProperties, Uri baseUri)
   bei System.Windows.Markup.XamlReader.Load(XamlReader xamlReader, ParserContext parserContext)
   bei System.Windows.Markup.XamlReader.Load(XmlReader reader, ParserContext parserContext, XamlParseMode parseMode)
   bei dataStandard.UI.XamlReaderImpl.Parse(String xamlString)
   bei dataStandard.UI.XamlObjectsFactory.CreateXamlObject[TXamlType](String fileName, IFile file, IXamlReader xamlReader)
   bei dataStandard.UI.MyViewDialog.CreateMyViewWindow(Object viewModel)
   bei dataStandard.UI.MyViewDialog.CommonShowDialog(Object viewModel)
   bei dataStandard.UI.MyViewDialog.ShowMyViewDialog(IList`1 documentInfo, IVaultSecurityInfo securityInfo, Dictionary`2 uiStringsXml)
   bei dataStandard.UI.MyViewDialog.ShowMyView(IList`1 documentInformation, IVaultSecurityInfo securityInfo, Dictionary`2 uiStringsXml)
   bei dataStandard.InvAddIn.EventHandlers.MyViewCallerBaseMulti.ShowMyView()
   bei dataStandard.InvAddIn.EventHandlers.MyViewCallerBaseMulti.TryExecute()
   bei dataStandard.InvAddIn.EventHandlers.MyViewCallerBaseMulti.Execute(IList`1 documentAndInterests, EventTimingEnum timing)
Unknown type {clr-namespace:CreateObject.WPF;assembly=CreateObject}ValidatedBinding
But why is this not working?
wangdu
The namespace that you have added in the beginning of the Inventor.xaml is the one for DataStandard for Vault.
xmlns:WPF="clr-namespace:dataStandard.UI.View;assembly=dataStandard.UI"
The one above is what you should be including instead of the ones from the vault.
Hope it helps!
Wangdu
coolOrange
www.coolOrange.com
Hi Wangdu,
thank you very much for your help!
Everything works fine now.
