Data standard poweshell errors CAD BOM tab
edarlak
edarlak
We are trying to evaluate the usage of Data Standard to customize BOM exporting with Vault Workgroup/Pro.  We are running into random powershell errors, see attached image.  It seems to be ransom .ps1 files where we receive the errors, nothing consistent.
We've migrated our files, we don't use virtual components.  This happens on all of our workstations, to maybe 25% of random assemblies in our vault.
I've tried uninstalling and reinstalling all Autodesk software many times.  I even started clean with a Win10 new OS install + Autodesk software clean install, same results.
I'm assuming this has something to do with the files in our vault?
upchurt
Hi @edarlak
Thanks for reach out on this issue via the forums. It sounds like the data standard CAD BOM is failing on some of your files.
Can you attach a sample file that is failing here or send it to me through a direct message? That way I can test this issue out and send it to development if needed.
-Trent
Trent Upchurch
edarlak
We figured out that the errors were due to the fact the structured BOM's were disabled in our .iam files.  Once we enabled the structured BOM, saved the file and checked back in, the errors went away.
