Custom Job Processor Configuration File
Is there any way to read from an assembly configuration file (xxx.dll.config) from a Vault Job Processor using the standard method of Properties.Settings.PropertyName?
I attempted to use a config file for NLog in a previous processor that I wrote, but none of the options were read (and thus logging did not work). Before I go down the path of rolling my own configuration, I wanted to check to see if I was doing something wrong or if the options need to be added to the JobProcessor config file instead.
Redmond.D
I've only used .exe.config files.  I'm not sure if there is such a thing as .dll.config files.  You will have to look at the .NET documentation from Microsoft to find out more.
I don't suggest adding your own content to JobProcessor.exe.config.  That's a component installed with the Vault client.  An update or hotfix may overwrite your change.  In my plug-ins, I usally just load the settings file directly from my code.
Doug Redmond
Software Engineer
If you have an addin called addin.dll, you can access its configuration file (addin.dll.config) like this
var executingAssembly = System.Reflection.Assembly.GetExecutingAssembly();
var location = executingAssembly.Location;
var config = ConfigurationManager.OpenExeConfiguration(location);
var sections = config.Sections;
string tempPath = config.AppSettings.Settings["OutputFolder"].Value.ToString();
Hope it helps
Nick
