Create PDF by API
Create PDF by API
marcelo.zatteraBGGNH
Create PDF by API
Hi for all.
Is there any way to perform PDF creation via API?
For example, do what the Create PDF button does but through the API.
dbyrdJKJBQ
There are a few ways to do this. I find the best way is to utilize the job processor. This can be done by using the default pdf job handler or creating a custom one. If that is not an option, this can also be accomplished by having inventor open the file, either visible or invisible, and exporting with the pdf translator addin. Is there a specific goal that you are trying to accomplish?
I believe that for what I need the best option would be using the Job Processor. Do you have an example of how to use the Job Processor?
