Configure Job Processor Use Limits for CAD Services for custom jobs
Majjek
Message 1 of 8
Majjek
According to the topic below in help, you can configure how many jobs per type will be processed, before restarting the CAD services (Inventor Server for example).
But how can we configure this for custom Vault jobs?
I couldn't find a setting for this.
Or is there a command to restart the services from the custom job itself?
https://help.autodesk.com/view/VAULT/2025/ENU/?guid=GUID-41C135C2-C437-45D3-9134-FD94CBDD6781
Replies (7)
Message 2 of 8
Nick_Hall
Hi Majjek
I've not seen any mention of this functionality working for custom jobs, so I would handle the restart process myself.
Hope that helps
Nick
Message 3 of 8
Majjek
Hi Nick,
What would be the proper way to restart them?
Message 4 of 8
Nick_Hall
Hi Majjek
There is an example of connecting to the Vault Inventor Server component here.
https://forums.autodesk.com/t5/vault-customization-forum/vault-2018-2-custom-jobs-using-vaultinvento...
I've not tried it, but I would expect a Quit method for Inventor Server API,  as there is for the Inventor API.
If you count the number of times your job has run, you can restart Inventor Server however often you feel is necessary.
Hope that helps
Nick
Message 5 of 8
Majjek
Hi Nick,
Yes, I know that post and also read through the example.
I couldn't find any 'closing' routine in that example.
The InventorServer object doesn't have a Quit method or something similar I could find.
So I hoped anyone else could help with this.
Message 6 of 8
Nick_Hall
Hi Majjek
I did say I hadn't tried it ...
But, as you can't close it tidily, I'd probably resort to the brute force method of killing the process, because life's too short (IMO).
You can get the process using Process.GetProcessesByNamehttps://learn.microsoft.com/en-us/dotnet/api/system.diagnostics.process.getprocessesbyname?view=net-...
The process name is VaultInventorServer.exe
Then use Process.Kill to kill it - https://learn.microsoft.com/en-us/dotnet/api/system.diagnostics.process.kill?view=net-8.0
It's not subtle, but it is effective. 😁
Hope that's of some use
Nick
Message 7 of 8
Majjek
Hi Nick,
Ok thanks for your reply.
That would be the only way then probably.
Since the VaultInventorServer.exe process is already automatically closed after a job has finished, I didn't look into this.
Maybe the automatic closing still holds some references in the JobProcessor process, to be able to restart it much quicker.
And maybed force killing it, will prevent this.
I will mark it as solved for now.
Message 8 of 8
Nick_Hall
If I ever get through my huge pile of jobs, I'll have a look at using Inventor Server from a job handler.
But that is a BIG if
Nick
