Checking in files from MS explorer
Timmy_Stalnacke
Timmy_Stalnacke
It would be good if it was possible to check in non autodesk files directly from MS explorer via right click and send to.
Daniel.Du
Hi Timmy,
I agree with you. I would suggest add this one into Vault IdeaStation, of cause you can do it yourself with Vault API.
http://forums.autodesk.com/t5/vault-ideastation/idb-p/2
Daniel Du
Developer Technical Services
Autodesk Developer Network
