_Category I cannot change manually
I have made some changes in the method "GetNewFileName" and I want to change the _Category of a new file manually. I assign the prop _category manually but Vault always put the "Base" Category for the new file...
$Prop["_Category"].Value = "Software_pasarela"
The file is created with all the properties correctly excepts the _category.
I am using Vault 2019 with DataStandard (customized)
Any idea of how to solve this?
Thank you,
wangdu
Give a look at the Vault rules.
Otherwise check the log file in the C:Temp folder.
Wangdu
coolOrange
www.coolorange.com
I forgot to say that I have removed the default combobox "Categories" because I will assign the category manually. I have opened the log
2019-08-14 09:02:58,601 [1] ERROR CreateObject.DsXmlLoader - System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
   en CreateObject.DsXmlLoader.<>c__DisplayClass7_0.<GetOrCreateDynamicPropertiesXElement>b__0(XElement x)
   en System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source, Func`2 predicate)
   en CreateObject.DsXmlLoader.GetOrCreateDynamicPropertiesXElement(XElement rootElement, String categoryName, String entityType)
2019-08-14 09:02:58,606 [1] WARN  CreateObject.DsXmlLoader - SaveCategoryPropertiesToXmlFile(): Failed to write properties for category '' in VaultDynamicProperties.xml: Referencia a objeto no establecida como instancia de un objeto.
I think the problem is the line "Failed to write properties for category ' '  ".
I assign manually the prop _Category but for some reason if the combobox "Categories" doesn't exist the property cannot be assign...
Thank you,
