Imagine life without web.archive.org
using System;
using System.IO;
namespace Vbaccelerator.Components.Algorithms
/// <summary>
/// Calculates a 32bit Cyclic Redundancy Checksum (CRC) using the
/// same polynomial used by Zip.
/// </summary>
public class CRC32
private UInt32[] crc32Table;
private const int BUFFER_SIZE = 1024;
/// <summary>
/// Returns the CRC32 for the specified stream.
/// </summary>
/// <param name="stream">The stream to calculate the CRC32 for</param>
/// <returns>An unsigned integer containing the CRC32
calculation</returns>
public UInt32 GetCrc32(System.IO.Stream stream)
unchecked
UInt32 crc32Result;
crc32Result = 0xFFFFFFFF;
byte[] buffer = new byte[BUFFER_SIZE];
int readSize = BUFFER_SIZE;
int count = stream.Read(buffer, 0, readSize);
while (count > 0)
for (int i = 0; i < count; i++)
crc32Result = ((crc32Result) >> 8) ^ crc32Table[(buffer[i]) ^
((crc32Result) & 0x000000FF)];
return ~crc32Result;
/// <summary>
/// Construct an instance of the CRC32 class, pre-initialising the table
/// for speed of lookup.
/// </summary>
public CRC32()
unchecked
// This is the official polynomial used by CRC32 in PKZip.
// Often the polynomial is shown reversed as 0x04C11DB7.
UInt32 dwPolynomial = 0xEDB88320;
UInt32 i, j;
crc32Table = new UInt32[256];
UInt32 dwCrc;
for(i = 0; i < 256; i++)
dwCrc = i;
for(j = 8; j > 0; j--)
if ((dwCrc & 1)==1)
dwCrc = (dwCrc >> 1) ^ dwPolynomial;
else
dwCrc >>= 1;
crc32Table[i] = dwCrc;
