AddFile and FileAssocParams argument
daniel_cadext
Advisor Advisor
daniel_cadext
I’m trying to use the add file method with FileAssocParams, but it seems I’m missing something as when I check the results in the thick client, I see an “Unknown status” icon, pseudo code.
Parent
foreach (child in children)
       childId = Vault.AddFile(null);
        Parent.addChildParam(FileAssocParam(childId))
 Vault.AddFile(Parent,  Parent.FileAssocParams)
Do I need to link the children with the parent too?
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
daniel_cadext
So, if I check the files out, then back in again, the status is ok. Do I need to call addFile and CheckinFile?
Or is there a way to update the status without re-sending the file?
Markus.Koechl
You can do this in one step by using FileManager.AddFile method. To get a better understanding of the FileAssocParam[] array, I suggest debugging a sample assembly file using GetLatestFileAssociationsByMasterIds. I recently created a sample doing this:
 #region capture dependencies
                //we need to return all relationships during later check-in
                List<ACW.FileAssocParam> mFileAssocParams = new List<ACW.FileAssocParam>();
                ACW.FileAssocArray mFileAssocArray = mWsMgr.DocumentService.GetLatestFileAssociationsByMasterIds(new long[] { mFile.MasterId },
                    ACW.FileAssociationTypeEnum.None, false, ACW.FileAssociationTypeEnum.All, false, false, false, true).FirstOrDefault();
                if (mFileAssocArray.FileAssocs != null)
                    foreach (ACW.FileAssoc item in mFileAssocArray.FileAssocs)
                        ACW.FileAssocParam mFileAssocParam = new ACW.FileAssocParam();
                        mFileAssocParam.CldFileId = item.CldFile.Id;
                        mFileAssocParam.ExpectedVaultPath = item.ExpectedVaultPath;
                        mFileAssocParam.RefId = item.RefId;
                        mFileAssocParam.Source = item.Source;
                        mFileAssocParam.Typ = item.Typ;
                        mFileAssocParams.Add(mFileAssocParam);
                #endregion capture dependencies
// checkin new file version
                VDF.Currency.FilePathAbsolute vdfPath = new VDF.Currency.FilePathAbsolute(mLocalFileFullName);
                FileIteration mUploadedFile = null;
                try
                    if (mFileAssocParams.Count > 0)
                        mUploadedFile = mConnection.FileManager.CheckinFile(mNewFileIteration, "Created by Custom Job executing iLogic : " + mAllRulesTextWrp,
                                                false, mFileAssocParams.ToArray(), null, true, null, mFileIteration.FileClassification, false, vdfPath);
                    else
                                                false, null, null, false, null, mFileIteration.FileClassification, false, vdfPath);
                catch
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
daniel_cadext
Hello Markus,
Thank you for your reply,  mFileAssocArray.FileAssocs  from GetLatestFileAssociationsByMasterIds is NULL as I’m attempting to upload the children first, they are new files, and they are not associated with any other file.
I then try to upload the parent last, but because there are no associations, I have no way to assign RefId
It seems your sample is for files already on the server, and already have associations, is this correct?
Best regards
Daniel
Markus.Koechl
Hi Daniel,
Indeed, my sample code was meant to analyze existing parent-child dependencies to better understand the FileAssocParam. You need to upload from child to parent while capturing each id and other parameters to build the FileAssocParam.
Markus Koechl
GeorgeWilliams
Via Fiddler, I can see that the Vault addin executes the GetLatestFilePathsByNames right before it prompts me to save a file before adding it to the Vault.  I am having sync issues adding Inventor files via the Vault API.  I am using the undocumented apprenctice call to get the refIds for the FileAssocParam objects but that is not solving the problem.  The expectedFilePath is correct as well.  The Vault addin resolver must be doing something that I'm not finding any information online to implement for a successful AddFile operation on Inventor assemblies.  Thoughts?
George Williams
D3 Technologies - Automation Solutions
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
