Add AD User, enable/disable user
wesbird
wesbird
  I'm working some admin tool, I did not find function to add AD (domain) user, enable / disable user. Where I can find them?
  Much appreciate and many thanks
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
wayne.brill
Hi Wes,
Did you try using the AddUser Method of the AdminService Class? This function is documented in the API help. (Search on AddUser)
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
wesbird
Hi Wayne:
  I do look at AddUser, but I miss AuthTyp part. Thank you,
  then how to enable or disable a user?
Many thanks
Wes
wayne.brill
Hi Wes,
The AdminService.UpdateUserInfo() has an isActive argument. Try using this to enable or disable  a user. You have to be logged in as an administrator to use UpdateUserInfo().
Wayne
Wayne Brill
ThomasRambach
Is there any examples to do this in powerShell?
