2017 Mass PDF upload issues...itemized names and description uneditable
timrobertsprovisur
timrobertsprovisur
Vault 2017 - we have 15,000 PDF files to upload, extract iproperties, add custom iproperties from our ERP system and re-insert with the new values.
The major issues we are facing are that the PDFs when itemized get an one-up number for the item number, we need this to match the filename...so users can search and find the item by filename.
So right now, we upload 000002-a.pdf - it's item number is one-up'd to 100024, we need the item to be 000002-a.
Also, we are extracting the iproperties and injecting fields from our ERP system and for the custom PDF category we created, we cannot edit the DESCRIPTION field. NOTE: If you upload a different non-cad data file like a .doc file, you can edit description...where is THIS setup and how?
Thanks in advance!!
Tim Roberts
wayne.brill
Hi Tim,
I am not sure of a solution for this. Can you provide code examples that are producing these issues?
If you are not using the Vault API please post these issues on the Vault forum.
http://forums.autodesk.com/t5/vault-forum/bd-p/101
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
timrobertsprovisur
Found the answers to my questions; to help others looking in the future, one blog that got me close on the Description field being editable was this one...
http://blogs.rand.com/support/2014/03/cannot-edit-user-defined-properties-in-vaulted-pdfs.html
Otherwise, see attached PDFs for additional info for how I solved these for my company and Vault 2017.
NOTE: I had already created the new PDF "file" category prior to these solutions.
Tim Roberts
