Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Plugin EBOM editor to have sort/reorder option
In thick client Upchain EBOM editor have option for designers to reorder the EBOM (rearrange the items with in the EBOM). Please bring this capability to Cloud version EBOM editor in plugin. Designers should be able to modify their view in EBOM editor in the plugin.
Use case is that while working with large assemblies it is very beneficial and easy for designers to rearrange all manufactured items, purchased mechanical items, purchased electrical items, sub assemblies, assemblies and product structure items together or in certain sequence and set spare flags or reference only flags.
With current fixed format, designers have to scroll through entire assembly to identify and set flags on certain items that were added/modified, which is very time consuming and also designers might miss some items.
2 Comments
Status changed to: Gathering Support
Hi @smaddukuri2KE8C,
have you tried using sequence number column in web BOM, for this request? It should provide same feature as you are requesting. Any feedback on this column behaviour?
Best regards,
Andreja Schneider
smaddukuri2KE8C
@andreja.schneider Sequence number in webapp lists the item and their level. From this request we would need the functionality to sort them. Each user would like to sort the items in eBOM based on preset sort.
For example With in a parent I would like to see all manufactured items listed first, followed by purchased mechanical, electrical, assembly and subassembly. And need this functionality in plugin.
