Welcome to the Upchain Ideas Board! Before posting, please read the helpful tips here. Thank you for your Ideas!
Advanced Search doesn't show Manufacturer column
In both the WebApp and the Upchain plugin, when you perform an advanced search, in particular for a purchased part, the Manufacturer attribute/column is not displayed with the results (unless you specifically search by that criteria, and in that case, it's shown in the WebApp results, but not the plugin results.)
2 Comments
Thank you for submitting this idea!
This idea has been moved into future consideration and we have all the required info. We will keep you informed if the status changes.
Best regards,
Andreja Schneider
eric.lepalud
Any update on getting this added? I just started using Upchain and this seems like a simple fix for this oversight.
It's quite sad to see that many of the ideas on this board that have been selected for "future consideration" in 2023 and at the end of 2024 they still haven't been implemented. All this after our Autodesk rep told me to check the Ideas board. Disappointing.
