Solidworks Toolbox Material
Drueda_TEC
Drueda_TEC
The Toolbox items are entered directly as Released items, in the toolbox configuration, you can specify the material which I want to put in the fasteners, or the quality of it.
When checking in the assembly, the material does not appear in the platform, because it is uploaded as Purchased Mechanical Item.
Would it be possible to enable an Item called for example "Toolbox Item" to read the material of the item, and finally put the item in Released?
Or is there any solution to be able to visualize the material of these items?
emily.caulfield
Hi Drueda, thank you for your post. I've played around with this for a bit and it looks like CAD mappings do not work with Toolbox Parts. Your idea is a good one and I imagine others would like to see similar functionality. Maybe post it to the Ideas Board?
Emily Caulfield
Senior Customer Advocacy Manager - Data and Process
Did this resolve your issue? Please click "Accept Solution" so others may benefit from it.
