Not able to sign in using the Upchain plug in in solidworks
francismb
Message 1 of 12
francismb
When click to the button to sign in on my PC, this is what it says. It was working a week ago but now it doesn't even open the browser. There is no available field to put in my credentials in the plugin, so how do I fix this?
Replies (11)
Message 2 of 12
gleb_tarasov
Some time ago, my colleague had the same problem. After a while, access appeared again. We think it might be an issue with internet connection.
Message 3 of 12
danijel.tot
Hi, can you try to delete following files (if they exist):
Directory: "%appdata%\Roaming\Upchain":
  • Auth
  • AutodeskConfiguration
Directory "%appdata%\Roaming\Upchain\Upchain CAD Connector":
  • All xml files ending with "_Settings"
Message 4 of 12
francismb
How long did it take to appear again?
Message 5 of 12
ryan.solomonUP7UF
Hi @francismb, can I confirm whether you have upgraded to 24.3 as per the plugin prompts?
Also I can confirm that the sign in with Autodesk should be the only available option. If you don't have one, you can create an ADSK account  and use the same email address that you've been logging in with
Message 6 of 12
francismb
Yes I have upgraded to 24.3
I already have an ADSK account.
Message 7 of 12
francismb
I tried this and the problem still persists.
Message 8 of 12
gleb_tarasov
Actually on the next day I think. He had the same problem when he is working from home, but on the next day he logged in through a computer at work and everything was fine.
Message 9 of 12
kristina_md
Hi Francis!
Would you please open a Salesforce case so the support Team can investigate this behavior and update the Development Team?
Kind regards,
Kristina Momirovic-Dedic
Senior Support Specialist
Message 10 of 12
francismb
Okay thanks. That is interesting because I am also working remotely
Message 11 of 12
francismb
Hey Kristina, I have already created one (they are working on it). Its pretty urgent so I'm hoping I can get information from anywhere I can at this point.
Message 12 of 12
francismb
Support helped me find a solution
I had to log out of my "Autodesk access" and log back in again. Still not entirely sure what caused the issue but his has fixed it.
