flat bom in upchain
flat bom in upchain
evandergoot
flat bom in upchain
evandergoot
is it possible to generate a custom BOM report in a flat structure? for example I have used the same bolt in several assemblies, now I want to now how many of these bolts are in the whole machine. like a flat bom structure.
if this can be done with Jaspersoft please provide an example
regards
emily.caulfield
Hi evandergoot, thank you for your question. I've asked a few people and they've said Jaspersoft is quite tricky to work with and probably not worth your time to figure out how to make it work for this request. Instead, I'd suggest exporting the BOM to Excel and using the tools within Excel to calculate the sums you need. You can either export from the web app or use the Excel plugin. Hope that helps.
wbarnardGTEV5
I resorted to writing my own macro in excel to crunch all the data down for our procurement team
SonicFlow
Can Fusion Manage do better? A flat BOM is an essential output for tools like this.  If not, this certainly belongs in the "Upchain Ideas" area to gather some votes.
HansChristianFossum
Fusion Manage handles flat BOM, but you will have to integrate Upchain and Fusion Manage.
SonicFlow
Is that difficult? I've used older versions. With the removal of the Upchain product name, I assumed integration would be a standard thing for FuMa (FuMan?) implementations.
HansChristianFossum
Autodesk moved the autodesk Fusion 360 Manage with Upchain offering to Fusion Manage. Same offering, just a different name.
 I haven’t integrated Upchain and fusion manage myself, but it shouldn’t be a big deal.
I got colleagues who can help.
