Article runtime by Workflow
LESAGE_ngounou
LESAGE_ngounou
When creating a workflow to release parts, I noticed that I cannot assign a value to the article runtime.
Can anyone tell me what the problem is?
Thanks for your help!
emily.caulfield
Hi @LESAGE_ngounou thank you for your question. It looks like you want to set an Item Maturity level, is that correct (I don't speak German and so I'm relying on my translation app 😄 ) ? If so, then you must first add the values that you want to appear in that drop-down list to the item maturity picklist. You can find this picklist in Administration > Engineering > Picklists. Here is an image:
Here is a help article on how to edit a picklist and here is a help article with more information on setting the update primitive for item maturity. Hope that helps.
LESAGE_ngounou
thanks you very much 🙂
