Message 1 of 1
API Method to Set Custom Attribute
Looking for confirmation on the correct sequence of API calls to set a custom attribute on an item. For example, I have an item with partVersionID 47351886 and a custom attribute "Revision Category" with id 1165 which is a picklist attribute and I want to set it to a new value (which has to be one of the valid values from the picklist).
So I think I need:
- Determine the list of valid attribute values per the picklist
- Can't see an API method to get this, but I could retrieve this manually and assume it doesn't change
- Determine the current value of the attribute on the item
- This endpoint appears to return that information: /api/item/v1/partVersion/47351886
- Set the attribute to a new value..
- I haven't tested it, but I'm guessing /api/item/v1/attribute/1165
- Does the item to target get controlled by the body of that request? So do I essentially send back the output of /api/item/v1/partVersion/47351886 with the value of the attribute updated?
- Update - this didn't work, returned Error 500, so I'm missing something
