API Method to Set Categorization Attribute
imckenzieY7CGY
imckenzieY7CGY
Looking for guidance on how to call the Upchain API to set a categorization attribute.
Say I have categoryId: 20 with attribute id: 1807, value type LOV - the list of values includes item indexes 1 thru 18.
For a particular item, which does not have any category information yet, I want to set this attribute to a specific value.
Do I call
/api/bom/v1/part_version/{partVersionId}/category_attribute
to accomplish this, passing the target partVersionId as a header - and do I have to do a POST to set versus a PATCH to change it?
What does the body of the request include to accomplish what I want to do? Am I missing any information if I have the output of the following call already:
/api/category_attribute/v1/20
  • API
mario_hoblaj
yes, for setting specific attribute LOV value to an item you can call that PATCH endpoint
You need to provide partVersionID as url param and Upc-Selected-Company (ID of your tenant).
In the request body you need to provide:
- attributeID - ID of you category attribute (you can find it by calling GET /api/category_attribute/v1/{categoryId})
- categoryID - ID of the category (you can find it by calling GET/api/category/v1/categories})
- itemID - same ID as for partVersionID
- valueLov - ID of you LOV category attribute (you can also find it by calling GET /api/category_attribute/v1/{categoryId})
Video example attached, please let me know if you have any additional question.
Mario Hoblaj
imckenzieY7CGY
Thanks for the reply - just tested this out and it seems to partially work, but I'm seeing slightly different behaviour in the webapp.
When I make the patch call, I get a 200 OK response indicating it went through, but when I view the categories tab as you show in your video, nothing is shown.
If I then click the '+' and go through the category selection, once I add the category and get to the view where I could set the attribute, I see that it is already set. So it seems like a step is missing for my setup..
My guess is that this is maybe related to our category hierarchy - the attribute I'm trying to set is for a nested category.. So we have category "CompanyName" with subcategory "DivisionName" that then has the LOV attribute I can set. Calling /api/category/v1/categories shows the parent category as id 17, with a 'children' array, which includes category id 20 and then /api/category_attribute/v1/20 returns the attribute I want to set.
Is there some kind of step where I need to set an attribute on the parent category to show the child category?
imckenzieY7CGY
Update on this - I think I've confirmed my suspicion. The "CompanyName" category has several attributes - one of which is a string which defaults to empty. If I just make a call to set it empty explicitly, the categories now show in the webapp with my previous update to the attribute I actually wanted to target..
I guess the safer flow would be to check if it has that attribute set already and only write blank if it's not set..? Or is there a better way to do this that I'm missing? It just seems that the child category won't show until I set *something* on the parent category.
