Announcements
Can I export a STEP file in Inventor Trial?
rwheat55
rwheat55
I need to export a drawing from AutoCAD with solids to a STEP file.  So MEP & Inventor provides this function - export STEP.  I open the drawing in Inventor (trial version - 30 days) and now I want to export to a STEP file.  But in Inventor Export -> CAD Format is grayed out.  Is this because it is a trial version?  Will this be fully functional when I buy Inventor?
Title changed by @LeoWarrenADSK for clarity. Original Title: STEP Export
LeoWarrenADSK
Hi @rwheat55,
A license shouldn't impact this functionality - when I opened the DWG inside Inventor with no processing, I faced the same issue.
However, if you open the DWG inside Inventor using File -> Open. Click your file then select options:
Select Import -> OK, then Open
You should see this window:
Select Default AutoCAD Configuration then Finish.
You should get a .iam file with your part:
This can now be exported:
You should then be able to export as STEP with no issues,
Please let me know how you get on or if you have any further questions,
All the best,
Please 'Like' posts that are helpful. If a post answers your question then feel free to click the 'Mark as Solution'
Leo Warren
Community Platform & Operations Manager
Are you a student? Come join our Student & Educator Community! | Education Knowledge Base | Rules and Etiquette
rwheat55
Thank you very much. This worked. Nice to know what you are doing 😊.
LeoWarrenADSK
That's great to hear @rwheat55,
See you around on the Community 🙂
Leo Warren
