토목 Civil 3D & Infraworks - 한국어
프로그램에 관한 사용 방법, 기술, 정보 등을 검색하고, 질문을 통해 서로 도움을 주고 받을 수 있습니다.
Infraworks Parametric model / Revit Family
11 REPLIES 11
Message 1 of 12
lkm5894
1097 Views, 11 Replies
When importing a Revit Family into Infraworks' Parametric Model, this error occurs.
Please let me know how to resolve it.
Tags (1)
Labels (1)
  • 2
11 REPLIES 11
Message 2 of 12
duckjin_kim
in reply to: lkm5894
I think it’s good you check the following list.
   1. type of family : could you check your family is profile family?
   2. category : have you set infrastructure category when you made it?
Please let me know the result after checking those.
Message 3 of 12
lkm5894
in reply to: duckjin_kim
Thank you for your response.
From what you mentioned, are you suggesting that I create a family using profiles? I have tried this method, but while the upper girder section of a bridge might show this error, the model still gets created.
However, when it comes to elements like bridge piers and foundations, I've typically used structural foundations to write them, but it didn't work. Even when I tried using profiles to create the foundations, the same error appeared, and no model was created at all.
Similarly, after writing the model as in your second suggestion, and setting the filter list in the [Family Categories and Parameters] menu to [Infrastructure] and checking it under 'Structural Foundations,' the same issue repeats.
Message 4 of 12
duckjin_kim
Could you provide error families to me?
It's helpful to resolve your issue if you would attach it on this board.
I'll let you know how to do for this issue or what's the better alternative.
Message 5 of 12
lkm5894
I tested it with very simple square box(Foundation).
I created a family using profiles as you suggested.
Message 6 of 12
duckjin_kim
I tested file you've shared and verified importing family into Infraworks well.
Please check below images.
(The reason why foundation is so small is there's no input parameter of width.)
Regarding import progress, I took 'foundation0730.rfa' from my local to parametric models panel in Style palette then set domain and component type only.
It's OK you would ignore and set in case unsupported model window is displayed.
There's no problem to set the library.
If you don't mind, could you write or update on Korean next time?
This is the Korean community that's why I expect good tech tips would be delivered more korean users.
Enjoy your journey with Revit and Infraworks for your project  !
Message 7 of 12
lkm5894
버전이 문제일수도있나요?? 둘다 2024 버전을 쓰긴하는데
저는 계속 들어오질않네요
혹시 매개변수까지 변경이 가능한 패밀리 하나만 제공 가능하신가요?
제가 만든 패밀리와 비교해보려고합니다.
Message 8 of 12
duckjin_kim
저는 Revit 2025, Infraworks 2025로 테스트했습니다.
본 기능은 2024에 업데이트된 신기능이긴 합니다.
일단 제가 가지고 있는 rfa 파일 제공해 드릴테니 테스트해보시기 바랍니다.
Message 9 of 12
lkm5894
제공해주신 패밀리로 Infraworks에 Import 해보았습다만 똑같은 현상이네요.
사진과 같이 Parametric Models에서 Import를 하면 역시나 처음에 보여드린 오류가 뜨며
모델 미리보기에도 나타나지 않습니다.
또한, 오류를 무시하고 진행해도 Revit 모델이 아닌 Infraworks 아이콘으로 모델이 생성이됩니다.
혹시 별도로 설치해야하는 파일이 있는걸까요??
제 PC에서도 그렇고 노트북에서도 그렇고 똑같은 현상입니다.
이런저런 방법을 다해봐도 계속 똑같은 현상이 나타나니 답답하네요.
다른 방법이 있다면 알려주시면 감사하겠습니다 ㅠㅠ
Message 10 of 12
duckjin_kim
제가 Revit 2024와 Revit 2025를 번갈아 테스트해봤는데, Revit과는 무관한 것 같습니다.
Infraworks를 2025 버젼으로 update해보시면 어떨까요?
별도의 add-in이나 업데이트를 설치한 것은 없습니다.
Message 11 of 12
lkm5894
Infraworks 2025, 2024 둘다 해봤는데 똑같은 현상입니다ㅜㅜ
도대체 뭐가 문제인건지 궁금하네요 ㅎㅎ
Message 12 of 12
duckjin_kim
제가 판단했을 때는 업데이트나 버젼과는 좀 무방한 것으로 보이긴 하는데요.
일단 저한테서는 동일한 사항이 발생하질 않아 정확하게 판단하기 좀 어려운 감은 있습니다.
Revit update 또는 Infraworks 2025 hotfix 같은 것들을 설치해서 테스트해보시라고 말씀드리고는 싶지만,
이게 시간적으로 할애한 것 대비 결과가 동일할 수도 있으니
그 부분은 한 번 구매하신 리셀러에 문의해서 case 지원을 받아보시는게 더 빠르실 것 같습니다.
