Hi All,
I'm looking for some advice for which laptop to purchase to run the following, Inventor / Plant 3D / Autocad 3D but also handle point cloud data so Trimble fieldlink and Recap, any ideas?
Thanks in advance.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
you can go to this link and select a software you want to use the most. Then, select the desired software version:
Here I attach the requirements for Plant 3D and Inventor:
It depends on the goals. If you only need a laptop for work, then MacBook will be a great solution. However, it is famous only for its speed, while it has problems with ports and not all programs work on MacBook.
I prefer the good old rule. Take a priority application/video game, look at its characteristics and choose a laptop based on it.
