CAM generating reversed toolpaths.
I have a simple test piece where that has apart surface that is .25 x 2 inch. There is a .020" deep .25" x .25" step at one end that needs to be cut. I use this to test the accuracy of the depth of cut. Previously the toolpath would start at the other edge and work toward the step (the riser). I went create a new tool path and now it starts by full slotting along the riser, and then working toward the outer edge of the part. Any idea why this is happening?
