Import Inventor project file, application & ilogic options.
andrew_canfield
Message 1 of 1
andrew_canfield
Hello
The options for Inventor are saved on a network drive & the files copied to the local work station as required.
Can this be automated (looking around I've found some options can be built into a deployment)?
Below are the steps I'd like to take:
Map network drive with contains the folder ‘CAD_FILES’ to the local machine.
Copy the project file (copy from ‘CAD_FILES’) to C: drive
  • Folders are saved on the network drive ‘CAD_FILES’
  • Design data - remain on network so all users can be updated
  • Templates  - remain on network so all users can be updated
Load applications options (import from ‘CAD_FILES’)
Load iLogic options (import from ‘CAD_FILES’)
A possibility for the last two requirements are listed here:
for iLogic:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
For Application Options:
https://forums.autodesk.com/t5/inventor-forum/start-inventor-with-fix-application-options/td-p/27565...
Regards
Andrew
Replies (0)
