Discipline Designator
Hi There C
I haD a question on naming sheet with the Discipline Designators. If i have a project starting with A-101, next will be A-102...can the next page be AE-103 ?
follow by A-104?
Is this possible on projects?
I will be glade on having a respond on this issue i am having.
Thanks Good day!
pendean
Community Legend
Community Legend
I work with Electrical projects and most of our project have only one Discipline Designator on each sheet.
If i start with a E-101....can the next sheet be ET-102 follow by E-103 ?
this is my issue!
having a sheet with 2discipline designators follow by a sheet with one discipline designator.
I am working with sheets not layers!
pendean
Community Legend
Community Legend
Contact your project lead (or the firm you are contracted to work for) and ask them about how they like to do it: mixing can be done but it is unusual.
Thanks . I have contact, the National CAD Standard Steering Committe to assist with resolution.
They stated that each discipline grouping would require its own set of numbers as follows:
E-101
E-102
E-103
ET-101
ET-102
ET-103
If you then add E-104 it would fall right after E-103 and before ET-101.
RobDraw
E-101
E-102
E-103
ET-101
ET-102
ET-103
I agree.
Rob
