Best machine for AutoCAD 2D
- Mute
- Permalink
- Report
The purpose of this discussion is to try to find what is the best machine for AutoCAD 2D. It is not a competition whose machine is better, rather: to find what is the best hardware and software to make AutoCAD fly.
Any comments very much appreciated. If I can edit this original post based on feed back I will do so to keep the best configuration at the top.
CPU
I think the best option is the smallest number of cores/threads and the highest frequency. i7 4 cores 3.4GHz is the best I could find. This CPU can go up to 4 GHz but it seems that this function is automatically controlled by the CPU and cannot be manually set to 4 GHz. The Turbo can be enabled (allow it to go up to 4 GHz based on temperature = work load) or disabled (stick to 3.4 GHz).
RAM
I think that 4 memory banks can end up the best option where each CPU core talks to one memory bank. I know the memory management unit (hardware) compounded with Windows paging work differently to this, but the idea is to have the least number of cores fighting over the most number of banks. Obviously all 4 banks should be the same (and maximum) available size and highest clock frequency. DDR4 is the best available for RAM at the moment and DDR5 at the graphics card.
Storage
Goes without saying probaly NVMs are many times better than SSDs. I believe one day we will get a new generation of MMUs (Memory Management Units) thay is based on the new hardware concepts not on legacy/archaic architectures.
Mother Board
The best MB with on-board Intel HD Graphics matching with the i7. They have 2 monitor outputs.
Graphics Card
None. Use the on-board only and disable Graphics Acceleration in AutoCAD. Your system will Fly. Tried the most expensive Quadros and GFXs and have found little difference in 2D work. It is possible that 2 cards: one Tesla to do the calculations and one Quadro for the output will take AutoCAD to the next level. If you have any such experience please share. Some people claim that Quadro hwarware = Telsta harware = GFX hardware but NVIDIA makes the difference by internally enabling/disbaling stuff to sell more graphics cards, but i can't see how going from 1 to None is any move in this direction.
BIOS
Disabling multi-threading for the CPU will have a negative effect as Windows is essentially multi-threading and has hundreds of (mostly useless) services running all the time.
OS
I think Windows 7 64-bits with all the updates is the best platform.
Choose Optimise for Best Performance and tick only the boxes you really don't want to sacrifice.
Services
Antivirus, Drop Box, One Drive, Mail etc. any app running and constantly using resources should be closed. Pause Synching. Close Mail and reopen every hour or so.
AutoCAD version
I don't really thing there is any difference between the various versions of AutoCAD. The engine is practically the same I guess, there are simply more and more tweaks in each new version. Even old versions that did not support tabs can become useful with one lisp or two.
The main trick is inside AutoCAD, need to lookup all variables that allow AutoCAD to relax drawing accuracy.
