Toggle Connection Pins
Chad-Smith
Advisor Advisor
Chad-Smith
It's been a little while since I last used Tandem, but it would appear there are has been a change in the way connection 'pins' are shown over the model.
I'm almost sure there once was a UI toggle to show them. This made it easy to hover your cursor over to read the data.
But now the Connections panel needs to be open for the pins to show. Have I missed something?
geoff_sdanoDTW54
Hi Chad-Smith,
There was a recent update that changed where to enable stream pins in the UI. You now need to ensure that your views have it enabled via the Labels tab at the bottom left of the screen. Once this is checked, you'll be able to hover over the pin to see streams as before.
Thank you!
Geoff Sdano
Customer Adoption Specialist
Chad-Smith
Thank you, that did it.
My problem was that Asset labels was disabled due to Levels and Rooms also being unchecked. After closer inspection there was a tooltip on Assets that Levels and Rooms first needs to be checked.
Not sure why it works this way, it wasn't very discoverable. If Level and Room labels are required for Asset labels, then when checking Asset labels, it should just toggle on Levels and Rooms.🤷‍
