Tandem Forum
Welcome to Autodesk's Tandem Forum. Please share your knowledge, ask questions, collaborate on ideas, and explore forum topics
timestamp value in the chart 1h in the future
3 REPLIES 3
giovanni.cov
694 Views, 3 Replies
i have setup an integration between home assistant and Tandem. the issue is that in the chart, the values visualized are read like "1h in the future", like if is 4:30pm, the chart is visualizing 5:30.
the problem is that the payload is correctly setup at 4:30.
"tra 42 minuti" means "in 42 minutes it will"tra 42 minuti" means "in 42 minutes it willthe payload it receivethe payload it receive
3 REPLIES 3
Hi @giovanni.cov ,
How are you sending the data to Tandem? If possible, can you export the data being sent to Tandem and check the time stamps?
Jessica
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
Hi Jessica,
thanks for your quick reply. It was a mistake in my json file, because i was sending the timestamp with a wrong time zone codification, taken from my operating system and not the actual software managing the sensors. Now it is working fine!
and.magro
in reply to: giovanni.cov
Hello @giovanni.cov,
Could you kindly provide some tips on your workflow for integrating Home Assistant sensors?
Thanks.
Best regards,
André Magro
