Steps to reproduce
Download the Postman collection from https://documenter.getpostman.com/view/15787353/UVeFMRdB
Under EAnvironment follow instructions to insert TandemSampleFacilityURN and TandemAuthToken
Expected results
Response from Website.
Actual results
Could not send request
Error: getaddrinfo ENOTFOUND {{tandembaseurl}}
Postman console
POST http://{{tandembaseurl}}/modeldata/%7B%7BTandemSampleModelURN%7D%7D/scan
Request Headers
Content-Type: application/json
Authorization: Bearer {{TandemAuthToken}}
User-Agent: PostmanRuntime/7.29.2
Accept: */*
Cache-Control: no-cache
Postman-Token: 2cf8a56a-e16f-4d8e-b7b0-bc7efeb6d5cf
Host: {{tandembaseurl}}
Accept-Encoding: gzip, deflate, br
Connection: keep-alive
Request Body
"qualifiedColumns": [
"n:!v"
"includeHistory": true
Base URL in environment is = https://tandem.autodesk.com/api/v1
URL where issue occurs
https://tandem.autodesk.com/api/v1 or https://tandem.autodesk.com/api/v2
Browser
Chrome
OS
Other
Solved by james.awe3P4Y7. Go to Solution.
RESOLVED:
After loading the Postman collection, documentation advises to update Environment variables.
However if you already had environment variables from other tests with Postman, you need to remember to set the freshly loaded Tandem Environment variables to be the default.
Then it works as expected.
Looks like you got it resolved. Here is a pic for others if you happen to run into the same issue.
