Importing Revit Model Into Tandem
seth.wilsonJYZT2
Message 1 of 8
seth.wilsonJYZT2
I created a new facility and brought in a test model from BIM360.  The test model has some architectural, mechanical, and electrical components.  Everything is in one model (no linked models).  There are a lot of components that do not show up in Tandem (Roofs, Ceilings, light fixtures, plumbing fixtures, mechanical equipment, etc.).  Are there factors that determine what comes through to Tandem?
Replies (7)
Message 2 of 8
jessica_smith
Hi Seth,
Are there multiple phases in your model? From the BIM 360 Tab, after you select your model, check to make sure that the correct phase has been selected from the drop-down. See the picture attached for reference.
What can happen on import when the user doesn’t select a phase, Tandem selects the most recent phase it thinks is correct.
Jessica Smith
Content Marketing Specialist, Autodesk Tandem
Autodesk Tandem | Subscribe Now! | Autodesk Tandem Resources
Message 3 of 8
seth.wilsonJYZT2
The model only has the default "existing" and "new construction" phases. Everything is on the "new construction" phase and that is the phase I selected when importing.
Message 4 of 8
AdamPeter
Hi @seth.wilsonJYZT2 on the files tab does it happen to show if the model has finished processing or if there were any errors?  I'm assuming the model is not missing any of those elements when you look at it in BIM360?
Adam Peter
Customer Program Manager
Message 5 of 8
seth.wilsonJYZT2
No errors and all of the elements are in the Revit model. I also checked the publish settings are using a 3D view with everything on in the model just in case.
Message 6 of 8
AdamPeter
@seth.wilsonJYZT2 , I know it's taken some time for us to respond, but after consulting with a number of product teams we've discovered a few things.  It may first help to know that this issue manifests in Docs and is exacerbated in Design Collaboration before it actually get's into Autodesk Tandem.  However, the issues persists in Tandem as well.
The root issue is caused by the current active view template in 3D view. During the generation of the master 3D view, we make an API call that pulls the active view template, not the default template.   So, if the active template filters out elements that's how it will get published to Docs, Design Collaboration and Tandem.
As a workaround you can set the active view template to "None" before publishing and that should resolve the issue.
Adam Peter
Message 7 of 8
seth.wilsonJYZT2
Thanks Adam, I'm still not sure what I need to do in the Revit model/publish settings to make everything come through into Tandem. Can you step me through it?
Seth Wilson
Message 8 of 8
AdamPeter
@seth.wilsonJYZT2 You can change this setting by going to the active view and selecting the "Edit Type". Once you are there you can pull down the list of view names and set that to none.
Adam Peter
