Import csv/excel of batch connections with threshold limit & unclassified element ?
aniket_pichakate
aniket_pichakate
Hi Team,
1. I'm looking to import my batch connections with user defined threshold limit using csv/excel.
2.Same assigning assembly code to unclassified element using imported csv excel.
Is there way to automate these two by excel or tandem connect?
iriacarreira
Hi Aniket,
Thanks for sending your questions:
For number 1 request at the moment, we do not have that capability but I will bring it up to the team.
Regarding number 2: you can utilize the export of excel file and then incorporate the assembly code or you can also utilize our Excel add in
https://help.autodesk.com/view/TANDEM/ENU/?guid=tandem-excel-add-in
Iria Carreira
Senior Product Manager, Autodesk Tandem
