Is it possible to delete unwanted historical time-series data of a stream?
Solved by arundhati.ghosh. Go to Solution.
Hi @hammad_haroon. Currently, the only way to erase the time-series data from the UI would be to delete the Stream Connection. Other options are:
I am curious about your use-case; are you intending to delete the historical data because it was unintentionally sent to Tandem or is there a different scenario you are trying to test?
I'm pushing data to Tandem through other methods, for instance historical data in csv format. This means i'm converting timestamps to epochs for example, but i made an error with the timezone (timestamp wasnt converted to GMT before conversion to epoch). If i fix it and send it again, it'll be overlaid with the existing data so i'll need to delete it and send it again.
To elaborate on this, while creating a test setup for feeding a temperature parameter value on a periodic basis, we accidentally submitted an incorrect timestamp in the payload. The timestamp was set for a future date. Now we can no longer update the parameter with new values with correct timestamps for "now". We would like a simple way to clear the history for this parameter. Can this be done?
Hello @robert_seliger ,
I chatted with the team about the best way to resolve this, and there are two ways:
If you continue to experience an issue with this, please submit a support case at https://www.autodesk.com/support/contact-support
