Can not see heatmap
semDZVNZ
Can not see heatmap
semDZVNZ
Hi All, i got a problem "this parameter is not configured for spatial heatmaps", i m using an Manual API. anyone could help why this message is appear ?
Best regards
geoff_sdanoDTW54
Hi semDZVNZ,
Can you confirm if the asset host that you assigned the stream parameter connection to, is assigned to a room under "Relationships"?
Geoff Sdano
Customer Adoption Specialist
semDZVNZ
Hi Geoff... thanks for your fast response. we are not setting a room for the asset. because we are trying to implement it in outdoor for solar panel power. we set a block of panel as 1 asset without a room.
Do we must set a room for it?
Best regards
geoff_sdanoDTW54
Hi semDZVNZ,
In order for heat maps to work when configured for spatial, the connection needs to have an association with either a room or a space. The other option is to assign the assets to a "System" and configure the heatmap to apply for systems. If your solar panels are part of a "power" system for example, you could potentially utilize this method instead.
Here are additional details that may help - https://help.autodesk.com/view/TANDEM/ENU/?guid=tandem-heatmaps
Thanks!
Geoff Sdano
semDZVNZ
Hi Geoff
Thanks you very much for your help and responsed. I will try and feed back.
Best regards
semDZVNZ
Hi Geoff
Thank you very much. Finally we can show the heatmap color using system. GBU
Best regards
Sem.
geoff_sdanoDTW54
Great to hear! Thanks for letting us know.
Geoff
Geoff Sdano
