@rogers.castro Have you installed the 2024.1 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2024 please.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
But first... consider fixing your file (and any XREFs) with RECOVER command.
ya se instalo y ya se hizo too pero sigue trabandose y dando error fatal
Bienvenido al foro!
Intente las sugerencias de los enlaces:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
