Generic User
Generic User
Mark.Lancaster
Consultant Consultant
Message 1 of 24
Generic User
Mark.Lancaster
This question has been asked numerous times on the forums and there's never a clear answer in what it really means.  I'm also starting to question the wording myself and I can see with this subscription change, more and more companies who are switching from network to single user are going to be asking this very same question..  Meaning if they are allowed to use generic login.
In this term of use https://www.autodesk.com/company/terms-of-use/en/subscription-types?_ga=2.183878753.69887588.1582048... , for single user, it states the following:
"If Your subscription for single-user Offering authorizes a “Generic Login,” then Your generic login and associated rights to the subscription Offering may only be used by one (1) individual Authorized User at a time and may not be shared and/or used by any other individual simultaneously."
So many have asked in the past is the offering to do so an exception I have to obtain from Autodesk or is it already allowed as long you abide by the rule it states?
The term starts out with:
If Your subscription is described as “single-user,” “individual” or “named user,” then You may only assign such subscription to one (1) of Your Authorized Users. The Authorized User must (i) be identified by a unique user identification (“Autodesk ID”) and (ii) be an individual, not a group or associated with a generic login (except as permitted below). The Authorized User must log in using his or her Autodesk ID to install and/or access each Offering, and no one else may access and/or use such Offerings using the same Autodesk ID.
Mark Lancaster
Replies (23)
Message 2 of 24
aaron.tw
Hey @Mark.Lancaster - I'll dig into this and see what kind of answer I can get for you.
Aaron Weiss
Message 3 of 24
aaron.tw
From our terms of use:  If Your subscription for single-user Offering authorizes a “Generic Login,” then Your generic login and associated rights to the subscription Offering may only be used by one (1) individual Authorized User at a time and may not be shared and/or used by any other individual simultaneously.
Key points of information:
  • This only applies to a select set of products with specific use cases - for example, CAM products that are tied to a machine on the shop floor rather than a single named user.
  • These products self-identify their documentation so when being set up by the user/administrator, the applicability of generic ID should be apparent.
Aaron Weiss
Message 4 of 24
Mark.Lancaster
@aaron.tw
Thanks Aaron.   I'm also updating what I heard as well in this other posting https://forums.autodesk.com/t5/subscription-changes/removal-of-nlm-is-short-sighted/m-p/9343932#M127
However can we be provided with a list of those applications that do permit the use of the generic iD?
Mark Lancaster
Message 5 of 24
amanda.k
Hi @Mark.Lancaster  - I'm finding out the answer for you on this, but it may take just a bit for the right contacts to be online today. Wanted to let you know we see this and will be replying with the answer as soon as possible. Thank you!
Amanda Pruyn
Principal Community Liaison Manager
Message 6 of 24
Mark.Lancaster
Now that we know the true meaning of when we can use generic IDs (well we really can't)..
One feature of the 2020 product line (and I assume the same going forward) if you don't know already..  Is when you go to manage your license,
Select Change License type
And since someone else is logged in, you can select to Switch User and the other person signs in.
Granted this doesn't help if you're not using the 2020 product line or don't have the extra license to assign to other users but wanted to point this out too.   But if you do have the extra license and a single machine you can toggle between users without the need to shut down the application..   Okay just a tip here (nothing here to see 😁)
Mark Lancaster
Message 7 of 24
lynn_zhang
Great observation @Mark.Lancaster ! Thanks for sharing this tip. 👍
Lynn Zhang
Message 8 of 24
But we don't? I can't see an update from Autodesk in this thread... I know you @Mark.Lancaster have said in another thread that you received a private message from someone on this but that's not the same as an official response from Autodesk.
Message 9 of 24
Mark.Lancaster
@Anonymous
This was not a private message or anything like this..  It was meeting with folks directly from Autodesk.   But you can take my information and go with it or wait for an offical word.  😁
Mark Lancaster
Message 10 of 24
But how are users browsing this thread meant to know that? I'm not having a go at you at Mark, it would just feel bizarre if this thread died down without an official reply, although it would not be surprising...
Message 11 of 24
Mark.Lancaster
@Anonymous
Understand..
However the info that @aaron.tw  provided above or this
Is the same info I heard or saw in the Autodesk meeting I attended..    Granted this are just words that you're seeing at this point and the meeting explained more in details.   I also think @lynn_zhang or @amanda.k  was looking into getting the list of Autodesk application that allow for this.   However I believe the list of these so-called application are few or limited.
Mark Lancaster
Message 12 of 24
amanda.k
Hi @Anonymous and @Mark.Lancaster ,
I am still working on getting an official list of allowed applications for Generic Users. The request had to be put into several teams here, all which are working together to provide that. I promise as soon as I receive this list I will post it here.
My sincere apologies for the delay - I will update as soon as I can.
Thank you!
Amanda Pruyn
Message 13 of 24
DarrenP
are the Vault products on this list?
especially if you use a separate machine for the Job Processor usually you will have a generic user for vault to do this
if not now you will have to have an actual user name in your Autodesk Account & inside of vault
which will bring up this issue: https://forums.autodesk.com/t5/subscription-changes/working-on-multiple-projects/m-p/9355601#M321
if the users current machine is being used to run job processor that will mean their machine will be running slow & they can't use another machine while this is going on since this will be a violation of the license agreement based on the above thread
DarrenP
Message 14 of 24
Hi @amanda.k , any news on this?
Message 15 of 24
petestrycharske
@amanda.k, good morning!
I've also been asked this question and was curious if you've received an update on the list of software that allow a generic user?  Hope all is well and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
Message 16 of 24
jonaskellens
We are also searching for this answer
Message 17 of 24
amanda.k
Hi @Mark.Lancaster  and all,
Thank you very much for your patience in the delay in this response.
Ultimately, there are currently no products available that support generic login. We will be updating our Terms of Use to reflect this.
We appreciate you calling this out to us and following up on the response.
Take care,
Amanda
Amanda Pruyn
Message 18 of 24
JamesMaeding
How do you define a generic login anyway?
From Autodesk's point of view, if I regularly sign into multiple machines, do I look like a crook?
CAD managers will be doing this all the time to troubleshoot a user issue.
I'll walk over and say "let's see if that happens using my windows profile", then I log into windows and sign in to open acad. Or I might use team viewer to sign in on a remote user and start acad to troubleshoot or just use acad.
How exactly will adesk decide if I am really using acad, or someone I crookedly gave the login to, or someone that stole the info somehow and then I don't know.
Can you point me to how that will go?
thx
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 19 of 24
theo.bot
Hi @amanda.k ,
Thank you for the update. So we can conclude that no generic logins are allowed to be used.
But for "system user" like Vault job processor we have a challenge, because there is no physical human that operates the applications (Vault, Inventor , AutoCAD) . So you have to create a generic login for each system user, because customers are not allowed to share login information.
What frustrates me, is that this question can be placed at different locations inside autodesk but the answers are different. I even get an answer today by a support case, that they don't think it would be a problem for compliancy if you stick to the rules of not sharing. The problem with this is that we (partner network) try to give good advise to customers, but in these senario's it's hard to do it correctly.
Can you find out for customers that using job processors if they are allowed to use a generic login, with the knowledge of not sharing the log in and can by used the login on one machine.
Message 20 of 24
rkmcswain
Based on history, and without any documentation, I'd have to guess that it will be treated like the old scenario with standalone licenses and multiple activations. They'll let so many slide through, and then when it reaches some limit that only they know, they'll start asking questions and/or denying access.
