Generic User
This question has been asked numerous times on the forums and there's never a clear answer in what it really means. I'm also starting to question the wording myself and I can see with this subscription change, more and more companies who are switching from network to single user are going to be asking this very same question.. Meaning if they are allowed to use generic login.
In this term of use https://www.autodesk.com/company/terms-of-use/en/subscription-types?_ga=2.183878753.69887588.1582048... , for single user, it states the following:
"If Your subscription for single-user Offering authorizes a “Generic Login,” then Your generic login and associated rights to the subscription Offering may only be used by one (1) individual Authorized User at a time and may not be shared and/or used by any other individual simultaneously."
So many have asked in the past is the offering to do so an exception I have to obtain from Autodesk or is it already allowed as long you abide by the rule it states?
The term starts out with:
If Your subscription is described as “single-user,” “individual” or “named user,” then You may only assign such subscription to one (1) of Your Authorized Users. The Authorized User must (i) be identified by a unique user identification (“Autodesk ID”) and (ii) be an individual, not a group or associated with a generic login (except as permitted below). The Authorized User must log in using his or her Autodesk ID to install and/or access each Offering, and no one else may access and/or use such Offerings using the same Autodesk ID.
Mark Lancaster
& Autodesk Services MarketPlace Provider
