Creating and Administering many named user accounts
AdammReilly
Message 1 of 23
AdammReilly
With the new changes to subscription going to the named user model, does Autodesk have any plans to help the creation of all those new user accounts that need to be made? Many of the users don't have an Autodesk account. Those that do, don't really know it as it was setup for them, or they have never used it since creating it.
I've had to make several accounts in the past few months, and I don't want to have to do that for 100 people. I also don't want to rely on 100 people to make their accounts. I want to make it a seamless transition that doesn't involve them, and something to generate a series of accounts from the administrators page would be preferable.
Adam Reilly
Civil 3D 2026
Creator A16 AI+ A3HVFG
Windows 11 Pro
AMD Ryzen AI 9 365 w/ Radeon 880M
LinkedIn
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Civil 3D Certified Professional
Replies (22)
Message 2 of 23
Mark.Lancaster
@AdammReilly
The only thing that is there is you can import users from a file (well copy and paste)..
But the user still needs to create their own Autodesk Account.   In the user management you are only linking their Autodesk Account to your subscription/product/contracts.
Mark Lancaster
Message 3 of 23
AdammReilly
And that's the rub. Now I have to explain to 100ish people to go make an account they've never needed before, then go through and link them...if and when they're created.
It's much easier when I have new hires, as I can add it as an onboarding item, but for users that barely use or the software, it's just a huge headache I'm not looking forward to.
Adam Reilly
Civil 3D 2026
Windows 11 Pro
LinkedIn
Group Leader badge
LinkedIn | Discord
Message 4 of 23
rkmcswain
@AdammReilly - if your organization chooses to go with the Premium offering, then SSO will be available to you, meaning your user's Autodesk account is tied in with your domain accounts.
We have this with Bentley and did not have to have hundreds of users making a Bentley account. One would think Autodesk's offering would be similar.
Message 5 of 23
Mark.Lancaster
@AdammReilly
Adding to @rkmcswain reply about the premium level (just in case it was missed in the info @rkmcswain  shared).,
To level up to the premium level, its a $300 dollars per license up-charge and this level is not available until June 2020.
Mark Lancaster
Message 6 of 23
Emily.M.Svensson
Hi @AdammReilly
Autodesk will be launching several changes in User Management that will quicken the process of creating named users. We will be releasing a bulk import capability that will let you import larger numbers of users from a csv file - this will be helpful when you do the initial transition. Down the line we will also introduce AD Group sync - if you set this up your users will be automatically added/assigned/removed based on your configuration. We'll also be simplifying the current user invite workflow so that it is easier to use for people who need to continue adding small numbers of users manually.
If you choose to turn on SSO authentication, then your users will not have to accept any invites or create their account - it will be automatically created for them with no work on the end user side. If you pair this with AD Group Sync there will be very little overhead for you or your end users after the initial set up. If you do not choose to turn on SSO authentication, your users will still have to verify their account and set up a password to log in.
I hope that helps!
Emily Svensson
Message 7 of 23
rkmcswain
@Emily.M.Svensson  - which ones of the things you mentioned are only available if the customer pays the extra $300 per license?
  • Bulk import
  • AD Group Sync
  • SSO Authentication
Thanks.
Message 8 of 23
JamesMaeding
@Emily.M.Svensson
Ok, just don't get too inspired by Bentley.
Their last round of "install and register our Communicator app or risk losing your licenses" was about as effective and successful as the current Democratic efforts to find a viable pres candidate.
Learn from their mistakes if you can talk to a few that went through it.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 9 of 23
Tarek_K
Hi @AdammReilly,
I just wanted to check in with you to see if you already had some time to read the answer to your question by Emily and also @rkmcswain and @Mark.Lancaster. (Thanks to the three of you for that input!)
Please feel free to keep us all in this topic posted if this is helping you or answered your questions. Dont hesitate to also ask if there are more questions in regards to your topic.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Tarek Khodr
Message 10 of 23
francis.s.m
  • Bulk import
  • AD Group Sync
Thanks.
I am very interested in an answer to this!  Is AD Group Sync and SSO going to cost an extra $300 per seat???  Really...
Message 11 of 23
chriswade
Is SSO and AD Sync going to only be in the premium version? I would hope not, that is something that is basic.
Message 12 of 23
Mark.Lancaster
@chriswade
Yes those options are only in the Premium level
@francis.s.m
Bulk import is already possible now..  So its going to be part of the standard level.   However I've heard that its going to be easier to bulk add (compared to now).
Mark Lancaster
Message 13 of 23
Emily.M.Svensson
Hello all,
Single Sign On and Active Directory Group Sync will be available for Premium and Enterprise tiers. More information about the features in each tier will be available soon. Bulk Import via csv will be available for everyone.
Thank you,
Emily
Message 14 of 23
JamesMaeding
@Emily.M.Svensson
So Autodesk found one more way to fleece us. You yourself must be in disbelief they only give out those tools to "Enterprise" customers. Like telling patients in the dentist waiting room "only those of you with PPO insurance will get novocain". Will Autodesk next charge extra for lisp compatibility? PEDIT command? LINE?
Shoot, now I am giving them ideas.
Message 15 of 23
chriswade
@Emily.M.Svensson wrote:
Hello all,
Thank you,
Emily
So, basic features that should be included in any scheme like this are going to come at an even higher premium and why? Just so Autodesk can milk even more money out of us in the guise of more insight into software use (insight that I can already get with our network licenses).
Message 16 of 23
michel.fontaine75
@Emily.M.Svensson when did the Active Directory Group Sync (Premium and Enterprise) will be availalble ?
Message 17 of 23
chriswade
It will become available only when your licenses are upgraded to premium licenses and this requires a minimum of 50 license and additional fees of something like $200 for each license.
Message 18 of 23
michel.fontaine75
Message 19 of 23
rkmcswain
@Emily.M.Svensson - can you point us to this information? The message above was 15 months ago. Thanks.
Message 20 of 23
chriswade
Here is the link to the different levels of subscription plans:
https://www.autodesk.com/plans
