I am new to Inventor after nearly 30 years using Solidworks. I am trying to add a middle constraint to position the pins center on the block plane. Solidworks had a constrain that I could select the two ends of the pin and the plane in the block, and it would center the pins. Is there any option in Inventor?
Solved by LeoWarren-EDU. Go to Solution.
Hi @rivnix,
You can constrain parts using work features such as planes, axis and points.
If you don't have the datum xyz planes in the right positions, you can create a plane as a midpoint of the cylinder and constrain to a plane that is the midpoint of the block.
To create a plane as a midpoint, in the part, go to work features -> midpoint between two planes, then select the top and bottom faces. A plane should then form in between the two faces, which can be constrained to.
I hope that helps, feel free to let me know if you have any further questions.
Please 'Like' posts that are helpful. If a post answers your question then feel free to click the 'Mark as Solution'
Leo Warren
Community Manager - Students & Educators
Are you a student? Come join our Student & Educator Community! | Education Knowledge Base | Rules and Etiquette
Hello, @rivnix,
Did my previous post help you?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information.
In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Leo Warren
