Autodesk products insist on only using the C drive.
glw527
Observer
Observer
glw527
Observer
Observer
Is there any way to install any number of these products on a separate drive?
rushabhthakkar_910
@glw527, Is there any specific error you see..? If yes, can you share a screenshot of it ??
Also see if this helps..!!
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-products-...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-do-I-install-o...
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
LeoWarren-EDU
Hi @glw527,
Some products like Fusion 360 can only be installed on the C drive due to configuration requirements. Other software can primarily be installed on an alternative drive, however, some data will need to be saved to the C drive such as user data.
I hope this helps,
Please 'Like' posts that are helpful. If a post answers your question then feel free to click the 'Mark as Solution'
Leo Warren
Community Platform & Operations Manager
Are you a student? Come join our Student & Educator Community! | Education Knowledge Base | Rules and Etiquette
