Structural Bridge Design 2022.1 is now available
simon_hooper
Autodesk Autodesk
Message 1 of 15
simon_hooper
Autodesk® Structural Bridge Design 2022.1 is now available to download via the Autodesk® Desktop App or from Updates & Add-ons for ASBD in Products & Services part of Autodesk Account.
The new features are detailed here.
The fixed issues are detailed here.
Simon Hooper
Software Development
Replies (14)
Message 2 of 15
StefanoPasquini6790
Dear @simon_hooper ,
This is a very great news, and for Robot Enthusiast users, and SBD beginner, this is like a dream.
Could it be possible to share some complete SBD model to test the Robot Model Creation? And to run some comparison tests?
Thank you in advance
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 3 of 15
We need that you update the beam types, it's very limited!
Message 4 of 15
Hello
Something is wrong with my ASBD software - it does not work with a results postprocessing. When I am trying to switch to result mode a set of mistakes warning windows appears - see print screens. After that the results postprocessing does not work properly - I can't choose an internal force in the "Result for" field.
vladimirprokopovich_0-1635939142947.pngvladimirprokopovich_1-1635939154188.pngvladimirprokopovich_2-1635939171497.pngvladimirprokopovich_3-1635939198883.png
Message 5 of 15
dave_geeves
It would be useful to "zip" up your data file (.sst) and any linked section and beam file (.sam if any).  If you attach it to a reply to this post then I will be able to investigate.
I look forward to receiving your file and hopefully resolving your problem
Kind regards
Dave Geeves
Message 6 of 15
Hi, Dave
Thank you for your response!
I did it, but this issue is similar for different project files. I have to notice that ASBD was working good previously. At least before 19/10/2021
Regards, Vladimir
Message 7 of 15
Hello, Dear Autodesk responsible people!
Could you, please, inform me - how is it going? I mean solving of the issues with the program which I was asking you previously. I already have two unsolved issues:
The first one is the problem with calculation of two staged construction of a post tensioned concrete viaduct.
https://forums.autodesk.com/t5/structural-bridge-design-forum/unexpected-interruption-of-calculation...
The second one is this - when the program became unable to show a result of calculations for all my projects.
I have to notice that these are not just computer games, but real structural project tasks with a deadlines and responsibility. Therefore, I must understand - what is going on? Are these issues are with my computer or settings of my operation system, or they are problems with the software, when and how they will be solved?
Additionally, I want to notice that the idea of this program is very good - it is really for thinking engineers, totally different from another ones "black boxes" existing on the market nowadays, thank you for this, but it must work!
Best Regards, Vladimir
Message 8 of 15
simon_hooper
Hi Vladimir
I loaded your file into 2022.1, analyzed all the loading sets, one by one, then analyzed the unassigned load cases and saved the file.  I can access the results without issue:
I am not sure what issue you are hitting. I have attached the file "analyzed".  Unzip and see if you have better luck viewing the results.
Regards
Simon
Simon Hooper
Message 9 of 15
Vladimir, I was with the same issue... Unhappy any virus or malware corrupted your files. My solution was reinstall the software... But in my case, because of the virus I did reinstall the windows and then work correctly! I hope helped you!
Message 10 of 15
Hi Simon
Thank you!
Unfortunately, I can not find the attached zip file "analyzed" witch you have mentioned. Also, are you sure that you are using the same version of the software us I? As I can see in window title on yours printscreen, you have tried in ASBD 2023, but I am using 2022.1
Best regards, Vladimir
Message 11 of 15
Hi Samuel!
Thank you, for your advises. I have tried to reinstall the software, but this problem has not gone... About the viruses - I have antiviruses corporate software installed on my computer - it is not finding anything wrong.
Message 12 of 15
Some types of viruses or malwares can not found by antiviruses, or in second case your system files are broken but the virus was eliminated! You must scan e recover any broken system file.
Message 13 of 15
simon_hooper
File attached.
Yes, I also tested in 2022.1...
Simon
Simon Hooper
Message 14 of 15
Thank you, Simon. Now it clear - about 2022 version. I've unzip your zip file with results data and have copied them to the project folder. It does not help. It seem that the problem is not with getting the results of analyses but with to see this results in internal ASBD viewer.
Regards, Vladimir
Message 15 of 15
Thank you, Samuel. It is out of my responsibility - to work with corporate anti virus IT protection system. I've asked our corporate IT support and they are working with my problem.
Regards, Vladimir
