Structural Bridge Design Forum
Welcome to Autodesk’s Structural Bridge Design Forums. Share your knowledge, ask questions, and explore popular Structural Bridge Design topics.
Structural Bridge Design 2019 is now available
48 REPLIES 48
Message 1 of 49
simon_hooper
4483 Views, 48 Replies
Autodesk® Structural Bridge Design 2019.0 is now available to download via the Autodesk® Desktop App or as a 30-day trial
The release includes analysis and design to Australian Standards 5100:2017. Full details of the new features and issues resolved with this release can be found in the readme here.
A new comprehensive Eurocodes examples manual is being finalized and will be released in the New Year with a new set of example files.
Simon Hooper
Software Development
48 REPLIES 48
Message 2 of 49
nathanyiel
in reply to: simon_hooper
hi mr. hooper. i am having a problem activating the SBD 2019. it says that my serial number is invalid, and i do not know why. i have been using the said serial number since SBD 2017 and 2018, as a student version. i have decided to update it  2019, and then the problem occured. hope you can help. i'd be grateful. thanks
Message 3 of 49
nathanyiel
in reply to: nathanyiel
Message 4 of 49
simon_hooper
Sorry to hear that.  Bear with me while I investigate.
Regards
Simon
Simon Hooper
Message 5 of 49
simon_hooper
Apparently other customers are experiencing difficulty with education licenses for Autodesk software. Please try these steps, which should fix this problem. There is a link at the bottom of that page to get further support if necessary.
Simon
Simon Hooper
Message 6 of 49
nathanyiel
thank you mr. hooper. i'll follow those steps and see if the problem gets fixed.
Regards
Nathanyiel
Message 7 of 49
nathanyiel
hi mr. hooper. i have returned my version to SBD 2018, coz i still encounter the same problem. maybe i can get a notification once the problem is solved. thanks so much.
Regards
Nathanyiel
Message 8 of 49
saberali.akbar
I am having the same problem as well. The product ID and the serial number given is for ASBD version 2018 when downloading version 2019. Hope they will sort the issue out soon.
Message 9 of 49
Hi Simon, i tried but it doesn't work. Its still giving me the id and serial number for older version.
Message 10 of 49
954K1 is the Structural Bridge Design 2019 product code
954J1 is the code for 2018 version.
Please let me know if that resolves the issue?
Simon
Simon Hooper
Message 11 of 49
Hi Simon,
The product key i am getting is for version 2018 and i did try the serial number given to me with product id of version 2019,But it says it doesn't match or wrong serial number. If i use the serial number for version 2018 it works fine.
Message 12 of 49
Thanks for letting us know.  Is that the educational version that you are running?
Simon Hooper
Message 13 of 49
hi,mr. Hooper. when i switch the code to eurocode, i cannot creat a "new post-tensioned concrete" in ASBD 2018 ,can i find a solution in ASBD 2019?  Or it's a bug when using eurocode to design beams ?  i coundn't find any answer in the examples manual or help files.hope you can help. i'd be grateful. thanks.
Message 14 of 49
simon_hooper
Post tensioned beam design is not available for Eurocodes (only available for AASHTO and British Standards).
Simon Hooper
Message 15 of 49
Thanks for reply,So post tensioned beam design for Eurocodes will be available  in next version?
Message 16 of 49
Hi Mr Cooper.
I am having problems with creating pdf documents using Autodesk Structural Bridge Design 2019. I am getting the error message shown below.
Message 17 of 49
simon_hooper
I'll pass on your PDF issue to the support desk.
Simon
Simon Hooper
Message 18 of 49
Rafal.Gaweda
Hi @Anonymous
Make sure this exe is not blocked by firewall
Rafal Gaweda
Message 19 of 49
simon_hooper
Hi 廖 兆
No sorry, we are focussing on other areas of bridge analysis.
Simon
Simon Hooper
Message 20 of 49
I am informed that the education license issue is is now fixed. Please sign back into educational portal and generate new serial number for Structural Bridge Design 2019.
Sorry for the inconvenience.
Simon
Simon Hooper
