Post Tension Beam Design
saberali.akbar
saberali.akbar
I have several questions regarding designing PT beam in SBD;
1 - My parabolic shaped tendon A seems like not symmetry and incorrect where when i check the losses results, the mid point and end point are different. ( Stress results also doest look symmetry)
2 - The top and bottom stress differ quite significantly compared to manual calculation at mid point during stage 1 and 2.
Stage 1 - Top 2.36Mpa (manual) 2.74Mpa (SBD)
                 Bot 7.24Mpa (manual) 5.73Mpa (SBD)
Stage 2 - Top -1.01Mpa (manual) 0.146Mpa (SBD)
                 Bot 22.13Mpa (manual) 17.403Mpa (SBD)
I attached the model as well as calculation for ease of reference. Appreciate help or suggestion from the team.
Regards
karoly_tarcsi
Anchor slip, friction and wobble losses are set for Tendon A on the "Loss of prestress" tab, therefore the total force after all losses vary along the beam. Set these losses to zero if you want uniform force or stress the tendon from both ends to get a symmetrical force plot.
2)
Here is how ASBD calculates stresses using the stage one top fiber as an example:
ft = F/A + M/Zt + Msw/Zt
where:
F: prestressing force: 4208.6*0.875=3682.52kN in the manual, 3248.58kN in ASBD = (Jacking force) - (Immediate losses) - (time dependent losses) as set on the losses tab.
M: bending moment from prestressing: 3918.207kNm in the manual vs. 3474.2kNm in the software due to the mismatching force,
A: area of cross section: 8.11*10^5mm2 in the manual vs. 8.01*10^5mm2 in ASBD, because the area of the tendon ducts are deducted from the area of the girder,
Zt: 5.073*10^8mm3 vs 5.023*10^8mm3 in ASBD due to the deducted ducts,
Msw: self weight moment: 2811kNm vs 2813kNm.
As a result of these differences:
ft = 3248.58/8.012/100-3474.2/5.023/100+2813/5.023/100 = 4.05-6.92+5.60 = 2.74N/mm2.
Note:
- Your slab thickness is 230mm instead of 180mm specified in the manual,
- Immediate and time-dependant losses cannot be set individually at construction sequence. In your example when the tendons are stressed to 50%, half of the total losses are applied.
Karoly Tarcsi
Software Development
Karoly Tarcsi
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
