Hi Mastan,
Thanks for you post.
Section analysis in ASBD may fail to converge in the presence of large axial force in some circumstances. Calculation of first yield moment is very sensitive to the initial iteration parameters.
I examined your model and I introduced some enhancements to to make it converge for all your axial force cases. See Coulmn 5.1x2.0 - Output_enhanced.pdf attached.
Unfortunately usual techniques like relaxing the tolerance to the balancing forces or converting arcs in the cross section to polygons did not offer any solve the issue.
The only way I managed to make all the axial cases converge is by reducing the start yield/stress to 0.00155 and 310MPa for the rebar material property. See Rebar_matprop.jpg and Coulmn 5.1x2.0 - Output_modified_start_yield.pdf.
By doing so, both the ultimate moment and the first yield moment will be slightly underestimated. See Workaround_vs_enhancement.pdf.
Karoly Tarcsi
AUTODESK
Software Development
(If you are satisfied with the answer, can you "Accept Solution ", so others can learn from it. Thanks.)
Karoly Tarcsi
