Structural Bridge Design Forum
Welcome to Autodesk’s Structural Bridge Design Forums. Share your knowledge, ask questions, and explore popular Structural Bridge Design topics.
How to define wind load on the structure?
2 REPLIES 2
leumelo
388 Views, 2 Replies
in the loads section i don't find the wind load option. How do i add this load?
2 REPLIES 2
dave_geeves
in reply to: leumelo
Sorry for the late reply to this.
There are no automated wind loads in ASBD but these are normally added as a series of joint, beam or element loads in a horizontal direction.  If you have modelled your parapets and beam webs with plate finite elements you can apply a suitable pressure load to specific elements. Unfortunately you will need to work out the equivalent load values for beams and joints.
Sorry I can't be more helpful.
Kind regards
Dave Geeves
leumelo
in reply to: dave_geeves
I was studying the subject, how can I create a workflow for RSA and generate the wind loads there and then apply the values ​​to the sbd but I was not successful in doing this, perhaps with a CFD analysis I can do it. Thank you for your attention to my doubt.
