Message 1 of 11
03:45 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello.
I work with the results of the calculation. I use reaction envelopes in supported joints. In the envelope table, the maximum reaction in the joint of interest (39) is 6281 kN for combination C31, together with combinations from dead loads (C5) and the effect of post tension. When I check a separate combination of C31, with combinations from dead loads (C5) and a post tension, the reaction in the same node is already 6724 kN! How can it be? What am I doing wrong? The problem disappears if I copy the file to another folder and do a recalculation, but I cannot do this for each of the dozens of combination...
