AS5100 Error in calculations
brett.jA2YMA
Observer Observer
brett.jA2YMA
Observer
Observer
There appears to be an error in the design creep coefficient to AS5100.5 calculations. It appears to just be a printout issue in the calculations rather than an actual calculation issue, as the correct value is used in the following section. Please review and advise if this is correct, and if this error affects any other calculations.
dave_geeves
I have reproduce this issue and checked the calcs with an independent spreadsheet and can confirm that there appears to be a problem with the printed value of k5 (and hence the following  printed value of phicc).  As you have already pointed out the correct value of phicc is then used in subsequent calculations (including the flexure calculations at the end of the report), so the overall result looks ok.
Hopefully the software developers will confirm this  and make a correction at some time.
Thanks for pointing this out - it is good to know that someone is checking the results printout.
Kind regards
Dave Geeves
simon_hooper
This is fixed by the update named 2022.1.1 Hotfix release (13 Jan 22) available via
manage.autodesk.com/cep/#products-services/updates
Simon Hooper
Software Development
